Anyone install flip up bow nav light in fountain
I installed 1 on my 93, 32 last spring. Used the drilled hole for the wires as the very front of the of the pop up bow light w/ a bezel underneath it.... It's scary cutting a hole that big in the front of your boat, but really cleaned it up!!! Used a whiz wheel I believe!? Kinda traced around the fitting, started small & kept cutting & grinding Lil by Lil till it fit snuggly!!!
I shaved the deck on my 1996 29' fever ( except for the rails ) when I had it painted. The pop up bow light was installed as well as a pop up cleat. We cut the holes with an air reciprocating saw with a fine edged blade. It turned out great.
My install complete !! I will attach pics (Warning! the images you are about to see are graphic in nature and could upset those who care about their Hull) not for the squeamish! these are in sequense , here is a link to pics
http://s1097.photobucket.com/albums/g360/blownincome1/
