-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   07 fountain 600 sci's (https://www.offshoreonly.com/forums/fountain/259000-07-fountain-600-scis.html)
JMPH 07-27-2011 01:13 PM
anyone having trouble throwing blades on xr's?
fountainwoman 07-27-2011 04:50 PM
We have a 42 with 600 sci bravo xr drives....
I have had 4 blade bravo and six blade Herings on her and have never thrown a blade.
rexcramer1 07-27-2011 08:56 PM
If your props are labbed then you might want to have a talk with the company doing the work.
Stock Bravo props should not be throwing blades
JMPH 07-28-2011 08:45 AM
apparantly it is a common problem because of prop surfacing and flexing the blade.
just wondering if anyone has come up with a solution.
Von Bongo 07-28-2011 09:03 AM
1" spacers :party-smiley-004:
m3seth 07-28-2011 09:08 AM
Mudslide from Knoxville TN is/was having the same issue with his 07 38. PM him, he may be able to help you out.
575cat 07-28-2011 10:15 AM
my new herings are being cast thicker at the base as per jeff at Hering
JMPH 07-28-2011 01:03 PM
I think that may be the answer!!
Beak Boater 07-28-2011 03:59 PM
Had an 06 38/600 XR drive boat. Ran 5 blade Maximus, never thru a blade, but did brake a drive.
JMPH 07-28-2011 05:35 PM
you will alway's break the drives, it's the weak link.
Have to upgrade to the IMCO scx. You can get away with with using the sc lowers for a while with the scx uppers.
