-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   First time Fountain owner with my first question... (https://www.offshoreonly.com/forums/fountain/263457-first-time-fountain-owner-my-first-question.html)
JD33 10-03-2011 10:54 PM
Hi guys, I recently became the proud owner of my first Fountain; a nice 32 with 525sc's. This is my first twin engine boat, and until this past weekend have had no real problems. My problem is I need to change the spark plugs in both engines; gas fouled them due to idling too long and being a nice guy and towing another boater home with a broken engine. Any body have any tips or suggestions on how to get to the sparkplugs between the 2 engines? The engines have the Gil exhaust manifolds and I don't see any easy way to get to them without some disassembly.
Expensive Date 10-03-2011 10:59 PM
I would just take it out get it up to temp. and run it wide open for a few miles.Unless you have other problems they should clean themselves.I can be done I have never done a boat like yours but I believe you have to get them from underneath.Or you could pull one Manifold inspecting it for leaks would not be a bad idea.
JD33 10-03-2011 11:10 PM
I tried that Sunday on the way to the ramp to put it back on the trailer, the port engine cleared up but the other still runs rough. The plugs I removed from the outer banks of the engines were very black from too much fuel, from what I've read these engines are over jetted plus my carb's need some attention, the engines would load up with fuel if you let them idle to long and a couple of times they even died while shifting in and out of gear while docking the boat.
Interceptor 10-04-2011 12:08 PM
I always relate replacing the center plugs on a twin engine boat to"pregnancy testing a cow " . A good animal vet has a long arm !
ed
US1 Fountain 10-04-2011 01:10 PM
From the front and from the back going under the exhaust. Not that hard of a job, unless you are a 'big' guy.
JD33 10-04-2011 10:16 PM
I was able to get to them by removing the hatch lift and suporting it with a couple of 2x4's on the outer edges, I was able to stand in frt. of the engines and reach under the manifolds, not too bad of a job. While I was there I ran a compression check on both engines just to get an idea on the condition and both checked out good. I'll fire them up Thursday evening and see how they sound.
Thanks for the info, I'm sure I'll have more questions.
Expensive Date 10-04-2011 10:25 PM
Congratulations on the boat.
JD33 10-04-2011 10:46 PM
Thanks! I'm already looking forward to next spring!
Once I know for sure the engines are ok I'm going to pull them out and replace the valve springs, take care of a couple minor oil leaks and a few other maintenence items and be ready to go.
triple 300s 10-04-2011 10:47 PM
congrats to a new MO owner!!!
