38 Fever Fuel tank size
Anyone know what size tanks came from the factory? 1990 38. I thought i read somewhere they were twin 90 gallon, but this season one tank took 93 gallons. I know i was low on fuel but not that low. Twin 110 maybe?
Tank Size
My book said my 1990 had 105s on each side. I put 97 in one side when it was empty.
the tag on my tanks say 89 gallons each
Originally Posted by good2go38
(Post 3547932)
I had installed new fuel senders this year, as the old ones didnt work when I bought the boat. When the boat took 93gallons at the gas pump, the gauge was a hair over "E" on the gauge. So guessing my senders are pretty close now. Thanks! |
Hey mild still have the trs showers
The tags on each of my fuel tanks says 105 gallon capacity, built in 1990. You should be able to check by removing the hatch cover under the bench seat to access the rear of the fuel tanks.
Originally Posted by Sick Stinger
(Post 3552247)
probably a safe bet to assume it has twin 105 gallon tanks, being its a 1990. I will look to see if the tank is marked. THanks guys!
Mine are 105 each and it's a 1991
| All times are GMT -5. The time now is 12:41 PM. |
