Why Did Fountain Switch to Bravo Props? >
Old 06-19-2002 | 07:35 PM
Beak Boater's Avatar
Charter Member # 545
Its my understanding that when Brunswick told Reggie that you will run Mercury parts. Reggie raised the X on some of his boats to try to recover the lost MPH, due to running the Bravo 1's. Bravo 1's will plane better than the Hydromotive 4 blade, but in most applications on Fountains the Hydromotive is faster on the top end. Gatorone, how did the 5 blades work with your set up? I think you had a 35 twinstep with 575's?
Beak Boater is offline
Old 06-19-2002 | 10:49 PM
GATORONE's Avatar
Beak,
The boat is running well , it will run 97 on the GPS with the 4 blades and about 94 with the hydromotives. I can only turn the hydros around 4900 ;should have the new Merc shorties next week to cure the rpm problem.
GATORONE is offline
Old 06-30-2002 | 09:09 AM
envision
Just curious how much the drive height might have gone up. The Fountain report says my 29 '02 is 19 1/2 and it has the 26 RH Bravo.
I am thinking about trying a Hydro but don't know if I need a 25 or 26. $490 seems to be the lowest I have seen them sold. Any used X models out there?
I bought the boat in Texas and it ran 75-76 on the speedo at 5300 but dropped to 73-74 @ 5100 at Chicago altitude and water.
FASTRICE
03-31-2007 12:12 AM
wnelles
18
05-24-2005 11:37 AM
HOTTZU98
3
05-13-2005 07:43 AM
Pismo10
5
03-26-2005 03:21 PM
Water Fountain
Fountain
21
02-27-2002 01:39 PM
