-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Bilge pump fritz (https://www.offshoreonly.com/forums/fountain/274838-bilge-pump-fritz.html)
soldier4402 04-23-2012 02:20 PM
Thanks thats what I will do if I cant get the old one out Ill just put another there, for back up.
soldier4402 04-23-2012 02:29 PM
http://www.sportsmansguide.com/net/c...utm_medium=cse
cheap enough
grapeape93 04-23-2012 07:05 PM
That is not the correct pump. It is this one. don't want you see you get a different pump and say that guy was full of it.
jpmarine/products/bilge/UltimaBilge.html
grapeape93 04-23-2012 07:07 PM
http://www.johnson-pump.com/jpmarine...timabilge.html
soldier4402 04-24-2012 06:36 AM
lol thanks
Wildman_grafix 04-25-2012 02:38 PM
I want to find one that has a remote pickup, so I can mount the pumps in front of the motors.
Wally 04-25-2012 03:38 PM
You wont find one unless you find a pump thats got a rubber vein impeller and can draw a vaccum to suck the water up. And it wont be callsified as a "bilge" pump. All bilge pumps i know of are centrifical design and must be submerged in liquid to actually pump...they dont pull the liquid into themselfs...they just move it out.
If you wanted to find a diaphram pump then that might be able to have a remote pickup...but i dont know of any in 12v that can discharge at the rate these bilge pumps do. :(
proboat-wes 04-30-2012 08:58 PM
just replaced 2 on a 29 fountain today for a customer,pull off the inboard exhaust elbows and pipes hang down and remove the 2 back screws,squeeze down in front and remove 2 front screws,cut wires and cut hose that you wont reuse.install new pumps,your choice,and new hoses and attach the new hoses to the thru hulls and thats about it,leave old hoses there
soldier4402 05-01-2012 07:27 AM
ok yeah I thought about that thanks. A long ace screw driver might do the trick as well if you could find something like that.
