32 guys help with gph >
Old 05-19-2012 | 07:05 PM
Default 32 guys help with gph
K so I'm thinking bout going to a twin set up. I found on here a 98 with twin 500 HP 502's running easy what kinda gph do u think I would put down?
dra200832 is offline
Old 05-19-2012 | 11:26 PM
Registered User
20-25 gph cruising and not running too hard. If you have more idling time in and out of harbors that number could go down to 15-20 gph. But just straight cruising at 2800-3000 rpm figure close to 25 gph. That is what my 35 with twin 500EFI's did.
Dkahnjob is offline
Old 05-21-2012 | 03:30 PM
Registered User
Asking fuel economy on a twin engine performance boat is like going on a honda civic forum asking towing questions. It will be horrible on gas. But like anything you have to pay to play.
sonickevin95 is offline
Old 05-21-2012 | 03:48 PM
That response didn't take long. Yes, of course it is horrible. But there are different ranges of horrible. I can understand wanting to know what to expect in the wastelands of horrible mileage!
Captain YARRR is offline
Old 05-21-2012 | 10:41 PM
It's nice to know, because the fuel gauges on fountains are pretty much useless!!!
jmoore1225 is offline
Old 05-21-2012 | 11:22 PM
32 vette's Avatar
How true! I will use half a tank of fuel before my gauge moves.
32 vette is offline
Old 05-22-2012 | 12:18 AM
Registered User
It is pretty common on a V bottom boat because of the shape of the hull the top 1/2 tank holds much more fuel than the bottom half. So once you get below a 1/2 tank the fuel gauge goes down really fast because the bottom half is really only 1/4 of the fuel.
On my boats when I get to 1/4 I am looking for a place to get more gas.
Dkahnjob is offline
Old 05-24-2012 | 12:33 AM
Yes, when it reads 1/4 your actually out of gas!
I found this out the hard way late last season, my gauge showed 1/4 as I was heading to get gas and after only a mile or 2 it ran out 20ft. from the gas dock.
JD33 is offline
Old 05-24-2012 | 06:16 PM
RICHARD CUNY's Avatar
JD I ran out of gas in my 32 early last season with 19 hours on my engines leaned it out 14,000 later I will never run out again. I just put the new tube type fule unit in my tank to correct the problem just as bad if not worse.
Rich
WATCHUS
RICHARD CUNY is offline
