-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Port Trim Cable Port (https://www.offshoreonly.com/forums/fountain/277777-port-trim-cable-port.html)
Fulltiltt23 06-02-2012 06:53 AM
What length cable do I need for a 42 lightning port side trim tab indercater
Fulltiltt23 06-02-2012 06:54 AM
also where can I pick up a manual for a 2000 42 lightning
SPEEDFREEK 06-02-2012 07:33 AM
I just replaced both of mine on our 38, the best thing to do is look for the number on the cable. They are made by Teleflex and the the number will start with a 3...... as they are the 3000 series cables, the last 2 numbers are the length in feet. I also cleaned the cable where it passes through the transom with acetone to help the 4200 seal and stick to the cable.
prostock85 06-02-2012 02:26 PM
Not sure if it helps but mine were in inches and written in white/stamped within 2 ft of only 1 side of the cable.
Downtown42 06-02-2012 05:38 PM
General Manuals can be downloaded on Fountain.com
http://www.fountainpowerboats.com/se...er_manuals.asp
Wes Burmark 06-02-2012 07:58 PM
My just replaced port drive cable on my 29' was 20'. It would be nice if there were a location on this site where all cable lengths could be located. Somewhere on here (maybe Q&A) a gentleman listed all of the cable lengths for his 32'. Hopefully someone will chime in with the info you need.
