-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   porta potty in a 29 fever (https://www.offshoreonly.com/forums/fountain/278068-porta-potty-29-fever.html)
speedfreek1 06-05-2012 08:22 PM
anyone know what size the opening is or could you could you mesure yours and post I need to buy one for this weekend but my boat is at the lake an hour away .. thanks in advance..
hieght
width
depth
flying J 06-05-2012 11:18 PM
I have a brand new one never used out of my 2004 Fever. I took it out when the boat was new and put it in the garage. You can have it for 50 bucks I'll be at the LOTO all summer or I can ship it. Call me in the evening if interested
405-388-6998
Jeremy
Mark D 06-06-2012 09:39 PM
Let's talk Porta-Potties....
Mine is in the garage so I measured:
12" Tall
13" Wide
15" Deep
It's a Porta-Potti 100 series, model 135 and I hope to never have to use it....
Wes Burmark 06-06-2012 10:42 PM
Mine is in the garage and I can measure it in the morning and let you know. It is connected to a pump out located on the starboard side of the boat.
US1 Fountain 06-06-2012 10:44 PM
12" Tall
13" Wide
15" Deep
Same one my 32 had in it. Also removed it and stored in basement.
THese are the small units. I 'think' that for most part there are only 2 sizes??? Anything taller won't fit under cushion.
Wes Burmark 06-07-2012 11:00 AM
As mentioned before, mine has a pump-out feature located on the back (pointing towards the front of the boat) on the starboard side. The measurements are 12" tall, 14.5" deep, and 12.5 inches wide. I had to space my PP up 1/2" so the lever would clear the bottom lip of the hinged and carpeted panel. My last boat had a PP w/o the pump-out feature. I guess it would depend on how close you are to the nearest pump facility but as little as these models hold my current thinking is I would rather have a PP that could be removed and emptied rather than having to find a pump-out station. My closest station is over 7 miles away. As others have mentioned you cannot go larger, especially taller, (there is a little bit of wriggle room for depth and width) as it will not fit under the cushion. Good luck. Remember to pick up deodorant and RV toilet tissue!
speedfreek1 06-08-2012 07:51 PM
thanks guys just got back on here. I got real busy ...
