Fpm "need help" >
Fpm "need help"
Fpm "need help"
Old 06-24-2012 | 01:38 AM
Default Fpm "need help"
I own a 2005 29'fever(REGGIE BUILT!) that I have modified, currently running a Dart 588 EFI engine with a bravo drive and -2 imco lower. I am also running an stellings e-box. My boat runs fast in rough water, My question is "Is the e-box a waste of efficiency" Martin Sanborn told me this was over redundant because the hull is designed with a extension box already built in? I am not sure if my prop shaft height, and X-Dim. are somewhat correct or if I am way off and loosing efficiency?
TALK TO ME REGGIE !!!!
DIRT173 is offline
Old 06-24-2012 | 07:29 AM
Message me your number & i will give you a call.
Reggie Fountain is offline
