-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   47 Lightning Imco SC #6 props (https://www.offshoreonly.com/forums/fountain/279523-47-lightning-imco-sc-6-props.html)
575cat 07-11-2012 09:31 PM
1 Attachment(s)
Got the spacers on last week and ran it around sat it feels allot better , boat feels lighter , running in 2 to 3 footers it was like a walk in the park , so far turning about 4800 at 90 but cant pull much more than that you can feel it fall back it needs more tuning with the 1.34 gears and bigger props , with the last setup Eddie had to lean it out quite a bit now with this setup it changed the game quite a bit . I did run it at 90 for quite a bit just to watch all the guages and every thing was just fine .
575cat 07-11-2012 09:37 PM
2 Attachment(s)
Got the spacers on last week and ran it around sat it feels allot better , boat feels lighter , running in 2 to 3 footers it was like a walk in the park , so far turning about 4800 at 90 but cant pull much more than that you can feel it fall back it needs more tuning with the 1.34 gears and bigger props , with the last setup Eddie had to lean it out quite a bit now with this setup it changed the game quite a bit . I did run it at 90 for quite a bit just to watch all the guages and every thing was just fine . You can see my strainer pressure reliefs working in the 1 pic blowing off I guess i know they work . Yes double post and yes these are not the 2-3 footers this is later in the day .
47 lightning 07-12-2012 07:57 AM
looks real good nice riding attitude.you might need some more prop diameter to make up for x height.that is why i tried the 18 diameter.had to customize the cav plate.
47 lightning 07-12-2012 08:02 AM
your hud or prop carrier is over 5 in in diameter so you loose a good part of the prop thats why i went with 18 in
575cat 07-12-2012 09:00 AM
I understand .
47 lightning 07-23-2012 11:19 PM
this is the thread where the performance numbers are and pics from dash from innotec
