FLOOR DRAINS on late 90's 32 FEVER - please read
on the late 90's FEVERS or at least the 32' the ENGINE BAY firewall ( between engines and back seat has 2 ( TWO ) drain holes at the very bottom of the V birth. They run to the CABIN in "tubes" ... Some guys have plugged them with silicone to stop water from working back into cabin. I did the same late last season , however it's raising a new question
when hosing out the main COCKPIT area floor and water runs in the two floor drains rear of cockpit RIGHT and LEFT side....... we cannot see WHERE THAT WATER DRAINS TO? it should be draining into the ENGINE BAY, but it's not ??
this concerning........ why isn't that water that drains from the COCKPIT area coming through those lower engine bay drain holes on the lowest point of the firewall? and if they do not drain there where exactly do they drain?
Does anyone have the schematics of the draining system on the late 90's FEVERS?
thanks
thanks
Here's a post from last month, it explained it all.
http://www.offshoreonly.com/forums/f...ont-steps.html
