-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   HP 500 losing RPMS (https://www.offshoreonly.com/forums/fountain/280245-hp-500-losing-rpms.html)
Dirtydeeds715 07-09-2012 07:07 AM
HP 500 losing RPMS
I have a 32 fountain with twin Hp500 carb motors, after i have been running the port motor starts losing about 500 rpms, i changed the plugs,filters wires, does any body have any ideas where i should look next? thanks
88bullet 07-09-2012 07:11 AM
compression and cyl leakage
Dirtydeeds715 07-09-2012 07:31 AM
the compresion was good, i should have added it only seems to happen above 3000 rpms.
Wildman_grafix 07-09-2012 08:12 AM
Did you check the timing?
88bullet 07-09-2012 08:48 AM
pick up in tank
Dirtydeeds715 07-09-2012 09:44 AM
i did check the timing when i did the plugs and stuff, i dont think its the pickup because the motor will turn 5200 rms the first couple times i run it up then after that is when it drops off.
88bullet 07-09-2012 09:51 AM
outdrive starting to tighten up after it gets warm??
KWright 07-09-2012 09:55 AM
When it warms up check your coil make sure its not shorting to ground will only do this when warm also check sensor inside dist for corrosion.
tman 07-09-2012 04:20 PM
+1 I had a bad coil wire that would do the same thing.
JoCo32 07-09-2012 04:39 PM
Mine was simular, check the ground for the ignition pickups. The nut was loose on the port motor and would only turn 4500 wot
