fuel level sensor
my 2000 32 fever fuel level sensor is under the back seat i filled the tank to the top it only read half tank i adjusted the 2 little adjsutable resistors on the top of the sensor now it reads full but i still dont know if it works. My question is how does the fuel level sensor come off the tank i dont want to break anything does it unscrew or does it just pull out
Sounds like you have a Livorsi sender or similar.
I had issues to dial mine in as well when I swapped out my old gauges for new ones.
I eventually took the sender out of the tank, hooked it up to the gauge and filled a jug with gas, put the sender in it and adjusted it so the gauge would show full. Also checked half and empty reading.
A bit of work, but I now trust the gauge.
bad luck that sounds like a gd idea but my question is how does the sender come out do i need to unscrew it or is it some type of fitting on it i need to remove i just dont want to break anything taking it out
If you have the same type as I have (Livorsi) it does not have a float. It is basically a pipe. Just remove the screws/wires and pull it out.
http://www.livorsi.com/catalog/senders.htm
http://www.livorsi.com/pdf/sender_sfw.pdf
Even if you sender has a float, you will be able to pull it out after removing the screws (just be careful not to bend the float arm).
had a new one installed (said it was a digital one) turn on the key it goes to full then will only show 1/8 tank....what size tank is in the 27 fever....i put in 30gal should be more than 1/8
