525sc fuel pressure >
525sc fuel pressure
525sc fuel pressure
Old 10-14-2012 | 06:42 PM
Default 525sc fuel pressure
Just ordered a Holley black. Their website says pump runs 140hph at 14psi..... Need to know if I need to regulate that down to 7psi?
It's a stock 1995 525sc
houde0069 is offline
Old 10-14-2012 | 09:09 PM
dykstra's Avatar
I would think so. PM GRIFF he is the resident 525SC guru.
dykstra is offline
Old 10-14-2012 | 11:42 PM
I would regulate it down to 7psi. Not sure if the needle valves would seal with too high preassure.
badluck is offline
Old 10-19-2012 | 08:28 AM
Yes, it needs to be regulated down to 7psi. Why the change? Stock pump is just fine to support it.
MILD THUNDER is offline
Old 10-19-2012 | 05:32 PM
Yeah, Why?
Back4More is offline
Old 10-20-2012 | 09:07 AM
Originally Posted by Back4More
Yeah, Why?
Long story short I thought the pump was bad.. Turned out it was the oil pressure switch. So now I have a extra Pump.
Old 10-20-2012 | 09:27 AM
Biggus's Avatar
FWIW, I'm not a fan of mechanical fuel pumps in hi demand applications. They all seem to gradually lose fuel pressure over time due to premature fuel pump cam lobes going flat. -Even with several different tipped push rods.
Swapping to all electric fuel pumps eliminates a source of metal in the oil.
Biggus is offline
