-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Stereo Amp Location (https://www.offshoreonly.com/forums/fountain/287913-stereo-amp-location.html)
Racerngr1 11-19-2012 07:35 PM
I'm seriously thinking about doing them where the mirror was/is. I've done the amp in the engine compartment and that never worked very well. Also, I use the storage under my seat for buoys and anchor all the time so that's not an option. Hmmmm, which way to go.....
redsled33 11-20-2012 03:22 PM
The other thing you could do with mounting the amps on the mirror you could put fans on them and get a piece of the mirror and make a false panel so it hides the amps. I thought about doing this just havent yet.
On Time 11-20-2012 04:01 PM
Originally Posted by mikesystem01 (Post 3817560)
i got both mine mounted down under the sink area and easy to get at and there not small amps either plus the wires are closer to the deck
Bingo. Me too.
Quebecfountain 11-21-2012 07:28 AM
There a picture of mine in mirror place, we made another smaller mirror and its perfect, also fit fridge and TV 22 ,lol
http://i148.photobucket.com/albums/s...lificateur.jpg
http://i148.photobucket.com/albums/s...r_album/tv.jpg
4bus 11-21-2012 07:39 AM
Where did you get that fridge?
My amps are in the side compartments of the cockpit. never had an issue with heat of water, and I got stuck in the rain a few times this past season.
I am also considering building an amp deck that hides the wires and installing above the sink as well. Easy access and more bling to show off :D
Quebecfountain 11-21-2012 08:06 AM
I found portable fridge / freezer, check at this link above, mine is other name but i think is like CF40 or CF50 (not sure now), 12 Volts & 110 Volts, automatic change
http://www.pplmotorhomes.com/parts/r...zer-fridge.htm
Philip Carnell 11-21-2012 02:47 PM
amps
What size is your boat? On my 35 I put them in the bathroom, on my 29 they are under the bar, never had any issues with them shuting off.
Quebecfountain 11-21-2012 03:18 PM
need to remove all stage of plexiglass on the bar to win space where you put amps,
also cut little bit radio frame on top to fits amps on the top
and for sure need rectangle amplifier to fit in that place,
Quebecfountain 11-21-2012 03:29 PM
http://i148.photobucket.com/albums/s...bum/photo3.jpg
http://i148.photobucket.com/albums/s...lbum/photo.jpg
