single engine 29 speed >
Old 11-21-2012 | 04:04 PM
Default single engine 29 speed
what would the speed of a 29' fever with an hp500 be. Also I'm thinking of going with a procharger so what speed would be seen
homan is offline
Old 11-21-2012 | 07:30 PM
If the 525 motors hit 75 (on an average) then you can pretty much back it off from there. Procharger, figure 20 hp per m.p.h. How much will the Procharger add? Would depend on boost. 5% increase in h.p. per pound of boost is an average figure to use (like the 20 h.p. = 1 m.p.h. increase).
Wes Burmark is offline
Old 11-21-2012 | 08:16 PM
Had a guy at my marina with stock 500efi. Ran 68 and 70 gps on a good day.
POWERPLAY J is offline
Old 11-21-2012 | 10:34 PM
Should run 73ish with the right prop.
ttuton is offline
Old 11-22-2012 | 09:11 PM
Low 70's is pretty average but I've seen 74 on GPS in the salt with my buddy and I and light on fuel
Racerngr1 is offline
Old 11-23-2012 | 08:35 PM
rw40426's Avatar
29' fever with 525 efi stock 26p bravo, I run 80 with good water.
rw40426 is offline
