what exactly are these holes for
I dont think they are the cause of your leak. They wouldnt be in the water at high speed.
your headers probably leak. look for signs of water dripping at the joints. Do you have a pic of your relief holes or hoses?
I'm new to the fountain family so please put my ignorance aside. The holes in question are 2 thru hull fittings on a 29 fever in the hull just above the drain plugs on the bottom of the step up, and are connected with 1 1/4" hose to thru hull fittings on port and starboard next to the bilge discharge fittings. I'm thinking could they be to ventilate the hull and if so do they actually work. 2nd. guess was were they for thru hull water pickups if the boat had twins.
We had a trip 42 that didnt have ball valves either. I don't think i have seen ball valves on any. And yes the hoses are to break suction
If water can get in, I would want a valve on it. Mine has one on this planing device and, yes, it is in a place that is near impossible to get to. But if my boat is taking on water from there, I'll find a way to get under the motor to shut it off!
