procharged hp500 carb in a 27 fever
Has anyone ran a procharger on their hp500 carb in a 27 fever step hull. If so what speed did you get and what prop size did you move up to. I am running a stock bravo 1 outdrive
You do that and your Bravo one's are toast.
that's not necessarily true.....
depending on your final HP number you can probably get near to low 80s and spin a 28p |
Well I hope I can get past 80 im running about 74 rite now with a 27 four blade
They say 20hp = 1mph. What Procharger are you installing? M1 is worth about 100hp or so
Which procharger and how much boost. with that information go to Bam marine and figure est speed. Average speed increase is from 10 to 20 MPH. Procharger do not hit the drive as hard. The key is having your carb set up right and upgraded fuel system. On my Baja I went from 66gps to 83.6 gps with 5Lb boost. I run a 28 bravo1 labbed for a great hole shot and switch to 32 non labbed for better slip number but lose a little on top end. Going to love the chime walk.
Well I am looking at a older m1 pro charger. I think I might install it myself and take it to a shop to have the oil line hooked up and the carb tuned in rite. I don't trust myself to tune it in. I'm hoping to be in the upper 80's
good luck and be careful. 27s are a handful once you get there
Originally Posted by 98Fever27
(Post 3853885)
| All times are GMT -5. The time now is 10:59 AM. |
