Fountain Engine Vents >
Old 02-20-2013 | 10:45 AM
Default Fountain Engine Vents
On my old scowl, the plastic engine vents have proved to be impossible to replace with billet- have tried the Dana Marine, which are the cat's pajamas finish wise, esp. with the engraved Fountain logo in the center -and because of the stripe on my boat they are not quite tall enough. I have seen some "taller" vents out there on boats and was simply wandering if anyone had a resource beyond Dana for that application. As an example:
http://performanceboatcenter.com/boa...sp?boat_id=650
I don't like plastic vents .....
SeaWeasel is offline
Old 02-22-2013 | 03:05 PM
you can buy the standard dana vents and make a bezel around it to fill the gap looks factory
tnt1 is offline
Old 02-22-2013 | 03:13 PM
I like it ... what is the material? That is exactly the problem I am trying to solve....
Old 02-22-2013 | 06:12 PM
3/16 polished aluminum cut out on a waterjet
tnt1 is offline
Old 02-24-2013 | 09:46 AM
tnt1 did you make that vertical vent ? I'd love to loose the 'glass ones.
Louie is offline
Old 02-25-2013 | 09:43 PM
bad judgment's Avatar
I am dealing with the exact same thing. I even looked at that same boat for comparison. Now I am having some cut out of 1/4" aluminum with a waterjet. I'm going to polish them and clear coat em.
bad judgment is offline
