Engine room clean up >
Old 03-06-2013 | 02:46 PM
looks great, night and day difference
sr73z is offline
Old 03-07-2013 | 01:11 PM
Looks good! What color Awlgrip did you use?
Pokher Ace is offline
Old 03-08-2013 | 12:07 PM
Default Awl grip
Snow white
jab052783 is offline
Old 03-12-2013 | 02:15 PM
Originally Posted by 4bus
I am in the process of doing the same thing, hopefully finish up tonight. Using white rustoleom enamel with 8:1 hardener. Mine is slow going because I would not remove everything at once, one side at a time cause my memory sucks. Tonight will be the 4th in a row
Attachment 495346
At my age I've started taking pics of anything I dissassemble...except for my wife's nities ! he he
Thunderstruck27 is offline
Old 03-12-2013 | 02:25 PM
Registered User
Originally Posted by jab052783
The tin foil trick works great even when you are spraying and not brushing
Im glad you tried that & it worked, I mentioned it in another post & I got some neg. feedback about it. The shop is warming up as I type, ill be painting in a few hours!! I better buy some more foil.
BTW, Those both look awesome!!
GTOKILLER is offline
Old 04-22-2013 | 09:33 PM
Default engine room refinish
Decided to give my engine room a coat of paint while I am waiting on parts for my engines
hello what are you using to prep the gel before you paint it
MIKE OLEARY is offline
Old 04-24-2013 | 09:11 PM
Attachment 495346
what did you use to prep the gel coat before painting ?
Old 04-25-2013 | 06:19 AM
I wiped it down with acetone. I did not sand. Paint is rock soild with hardener, couldn't be happier.
4bus is offline
Old 04-30-2013 | 10:57 PM
johnnyboatman's Avatar
I did the sides of mine in white, and the bottom in alum silver, looks ten times better, will post pics when I get all my tools out of the way.
johnnyboatman is offline
Old 06-01-2013 | 10:35 AM
Default Engine start
trim.m7CrbV.MOV
500efi with the kits from ateco would of been in the boat but my daughter has been in the hospital for the past 2 weeks and she comes first
