Spark Plug Wires help >
Old 05-20-2013 | 12:51 PM
Ignition Parts mag star Wire Sets.Ignition Wire Set 120/140 discount high voltage ignition wire sets, s.s. coil core magstar v-6 wire sets, v-8 magstar ignition wires discounted, mercruiser h.e.i. ignition sets, tune up wire sets, high voltage igniti
for 502s
boatnt is offline
Old 05-20-2013 | 12:58 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I'd be very interested to hear if any of these other kits like the two posted above and the MSD custom option provide any stereo feedback. Using the LS1 GM kit probably would not.
Sydwayz is offline
Old 05-20-2013 | 01:02 PM
rgrgoog's Avatar
I got the MSD 31489 wires from Teague for my 502s. About $90 a set.
rgrgoog is offline
Old 05-20-2013 | 07:01 PM
Not to be a jerk but I am aware that there are alternatives out there for 502 and 454 motors but the EFI 496 mag ho motors are a whole different story I did a lot of homework on this and the best solution I could come up with is the MSD wires.
As far as stereo feedback I did ask about that and they said that it should not be a issue at all. Only time will tell.
FIVEPTOHH is offline
Old 05-20-2013 | 07:09 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I remember cutting and installing Accell wires (big fancy 8.8mm yellow ones) for my Trans Am, in a military base parking lot some 20 years ago. I had a fancy stereo (for the day) at that time as well, and I had a ton of feedback. It's probably much different nowadays with electronic ignitions; but the memory still remains.
Sydwayz is offline
Old 05-20-2013 | 07:12 PM
thats why my first post was for 496 ignition wires...just click on the link above
boatnt is offline
Old 05-20-2013 | 07:27 PM
I haven't been keeping up with the general forums, but Raylar used to have lots of sets of the 496 plug wires that were "take-offs" from the packages he made. Could probably search on here to see if he is still around. I think he was somewhere under $100 for a brand new set of Merc wires for the 496s'.
bob_t is offline
Old 05-20-2013 | 08:58 PM
I emailed Raylar yesterday and never got a response. When I was searching this problem out I saw his name mentioned a lot regarding the plug wire problem and at one point he said that he no longer had any take off wires..?
Old 05-20-2013 | 11:37 PM
Originally Posted by txtraveller2002
Just wnet through this a couple of days ago. The late 90s Corvette set will fit. Mine are BWD supermags. Part number is CH869. One of the short ones has a straight boot, and is kind of a PITA to get on, but the rest will work.
Craptastic....sorry, stand corrected, I didn't see the 496 part. the vette plugs work for 502s.
txtraveller2002 is offline
Old 06-07-2013 | 10:39 PM
The plug wires that I ordered from Summit Racing worked perfectly.!! Way cheaper than Mercs and they all fit no problem. I had to cut all of them down and I used the 90 degree boots instead of the long straight boots. Big money saver!!
