Adjusting Drive Indicators
QUOTE=Wes Burmark;3939692]Ford F350 - When I first got my Fountain in 2011 the port drive indicator had "limited range" just as you described. I too, took apart the cylinder thinking that it could be the reason the indicator would not travel its full range. The cylinder was not the issue. I had to replace the cable.
There were two different qualities of cables with the top quality costing only about $5 more. I had the cable replaced (about a $50 item) and the indicator worked perfectly. The starboard cable lasted a year longer. Now I just need to get the indicator dialed in which appears to be an easy process thanks
to the knowledge of folks on this forum -
Good luck.[/QUOTE]
Good luck.[/QUOTE]
