My friend sprayed acid solution on the bottom of my boat, am I screwed? >
Old 08-28-2013, 11:56 AM
Ive never heard of using aluminum brightener acid on a hull. Muriatic acid, yes. I don't use any thing other than the "works" tub and tile cleaner in a spray bottle now. Works fantastic and doesn't burn the gel.
MILD THUNDER is offline
Old 08-28-2013, 02:15 PM
And if you have a real bad scum line... The "Works" toilet bowl cleaner Gel... The gel is good it doesn't run right away.
MissBehavin777 is offline
Old 09-08-2013, 08:45 PM
Its like hull cleaner. I use it on mine.. well the hull cleaner, but you have to come back and wax it or you will have to use it again b/c a short time in water will put those lil stains back on..
nailit is offline
