US-1 how do the rams/hydraulic motor packs attach in the upper frames? Are they just bolted in up there? Also how did your seat attach to the floor? Id take mine out but if the thru-bolts have nuts on the bottom, theres no access to those so id be f$$#@%%^ if they fell out when I took the bottom bolts out. Id like to take the ram out instead of the whole seat.
My 99 is electric. My 94 had the hyd pumps in the bilge. So not sure if same but can't see why not. Just a bolt and nylock up top. If I recall, it could be done but it looked like it would some head scratching and patience. The base is just lag bolts into floor. Thus why you see no access to the underneath.
| All times are GMT -5. The time now is 05:49 PM. |
