29 fever with twin 454s both leaking on lower port side of motors
Fired up the ole girl at the ramp and to my disgust both motors are leaking water from the lower (under) side of the engines. Both are leaking from the same (port) side. Is this some type of heat exchanger that I can't hardly see? It appears to be some type of black plastic cover with a few hoses running in and out that the water is coming from. Can this be fixed from inside the boat or am I going to have to pull motors?
