Fuel Starvation Help Please >
Old 07-09-2014 | 12:41 PM
Default Fuel Starvation Help Please
Hi Guys. Only been in the Fountain family for 2 months, and need some advise. 99' 42 Lightning, on main tank stock hp500 port motor runs out of fuel over 3500 rpms, and starts sucking air and stalls. Anything under 3500 its fine. After changing coil, fuel filter, fuel pump, switched to saddle tank, and it runs perfect. Is this a pick up issue in main tank?
MR_SRL is offline
Old 07-09-2014 | 01:03 PM
99 power? Assuming carbeurator could need carb cleaned.
Crude Intentions is offline
Old 07-09-2014 | 02:36 PM
Sorry I didn't mention, Stock hp500s
MR_SRL is offline
Old 07-09-2014 | 02:41 PM
Check your float levels (probably secondary) with the boat at the same angle as in the water, idling. It may be too low or the float is sticking not allowing enough fuel.
WHIPLASH is offline
Old 07-09-2014 | 03:57 PM
It could be a vent issue, plugged or collapsing. Or the fuel supply hose could be weak and collapsing in heavy demand.
Meshikinquah is offline
Old 07-16-2014 | 10:47 AM
On Time's Avatar
Yes check fuel line. The plastic liner in my 2005 with stock fuel line collapsed. Ethanol effects?
On Time is offline
Old 07-16-2014 | 08:24 PM
I Agree check lines coming from main tank and the vent if it works on saddle tank.
If it was the carb it wouldn't matter what tank you were on.
Wildman_grafix is offline
Old 07-17-2014 | 09:56 PM
same situation here, couldn't rev over 2600 rpm while in gear, but rev up fine while not in gear. what could possible cause? 557 engine/8-71 blower/750holly/Accel Igntion box
steven0720 is offline
