700sci motor dying - 42 Fountain lightning
Boatnt has real experience with this, I don't. I'm just helping with parts look up.
Look here : http://www.mercruiserparts.com/Show_...ents%28NXT1%29
#31 is Gear Indicator Switch Assembly
and #15 Shift Interupt Switch Assembly
now disconnect 31 the gear indicator and try it,the gear indicator is a input to the ecu and controls the rev limiter in reverse,,if bad or not adjusted correctly the ecu thinks its in reverse and activates the rev limiter,
when disconnected it thinks its in neutral and will run fine
Try taking the IAC off of the motor that is running right and put it on the other motor it's only two bolts and a plug. Really simple to eliminate this part. I'm guessing you're not getting any faults when you scanned the ecm or alarms
I meant call them on the telephone. 920-921-5330. Give them your serial number, describe your symptoms. They have the most experience troubleshooting issues such as yours.
