Looking at 29 Fever
I am looking into buying a 1997 29 fever with a single 502. I have one lined up, just want to know if there is anything I should know.
I belive the owner says it runs about 65 with that motor, dont know what happened to the original motor. I now own a 1988 checkmate convincer with a 598 ci making about 750 hp, the boat runs 80ish. Wondering what the fountain will run. I have a bravo x upper and a imco -2 lower, the fountain has a stock bravo set up, but it is counter ro. Which set up would you guys run. I was told to make my set up a counter ro. all I have to do is change the way the shift cable works. Just make it push instead of pull ? I hope to go for a test ride before this weekend, if all is good it will be mine. |
Keep the fountain counter clockwise. That model is set up for that rotation. Clockwise prop will tilt the boat.
| All times are GMT -5. The time now is 08:15 AM. |
