-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Props for a 42 non step w 500hp's (3) (https://www.offshoreonly.com/forums/fountain/31767-props-42-non-step-w-500hps-3-a.html)
Push-N-Throttle 08-27-2002 01:03 PM
Just looking for some feedback on prop set up, I have a 94 lightning and looking to have a better prop set up and looking for some history. Currently running 28 pitch mach's, they actually do ok for what I have in them. Any idea's? Thanks - Cincinnati
later 08-28-2002 05:50 PM
push-n-throttle
i have own 2 42's over the last 8yrs a 90 non-step and my present boat a 98. im sure fountain used a 4blade hydromotive on its 500hp 42's in 94. probably a little faster on top end than a bravo 1. what kind of rpms and speed are you getting out of your machs that will be the starting point. my quess is that regardless you will probably benifit from a hydro or bravo 1 try and borrow some props before buying. for example 26 hydros or simular to 28 bravos almost always 2pitch size different. across the line good luck.
candyman35 08-28-2002 07:28 PM
I'm sure Midnight will have an answer for you. The stepped triples were running Hydro's from the factory.
Dan
Push-N-Throttle 08-17-2004 02:16 PM
Re: Props for a 42 non step w 500hp's (3)
Thanks - I tried a set of bravo 1 and picke dup some rpm from the machs - I turned the bravo1's at 5100 rpm at 80 mph, The machs were turning 4900 rpm at 80 - but they are a cheaper prop and I go thru them real quick, they bend real easy. I would like to see what the hydomotives would do! hard to find some one that has all the right props and will let you try them on triples! Oh well at least it's fun to keep trying!
tomtbone1993 08-18-2004 03:17 AM
Dan
Midnight was getting 91MPH wasn't he?
Push-N-Throttle 08-18-2004 06:45 AM
he must of had more than just props if he was hitting 91 - 81 would be about right with hp500's
US1 Fountain 08-18-2004 07:08 AM
42 with triple 525's= 93mph
Downtown42 08-18-2004 08:45 AM
Upper 80's-lo 90's with 94 42 triple 500 is what I remember from similiar rigs. 80 seems low on WOT for your rig. Is this a GPS reading??
What does factory test sheet say?
tomtbone1993 08-18-2004 12:51 PM
I have "Midnight Riders" old boat, I will be running the boat for the first time today or tommorow. I have redone all the engines. triple 540's
