-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   What oil do you run? (https://www.offshoreonly.com/forums/fountain/322346-what-oil-do-you-run.html)
harleyrider 01-22-2015 07:45 PM
What brand oil and weight of oil does everybody run in a HP500?
Drew555 01-22-2015 07:57 PM
:food-smiley-007::479::
Brandonb_05 01-22-2015 08:08 PM
+1 :argue:
Here we go.
Flightplan 01-22-2015 08:18 PM
I sure wish we had an oil viscosity engineering professional on the forum... When does Borgay get back from banned camp?
38 X 01-22-2015 08:48 PM
Following for the drama lol
1989mach1 01-22-2015 09:22 PM
It sounds crazy but im kinda going through the same mind blow myself. I had the boat for three years. After first season it went in and had one full rebuild and the other had complet top end. Thay did the brake in oil. Then 15 hours they did the oil again. They also did gear lube every time. That brings me to now I am looking to run royal purple gear lube. But am undecided on the oil I am going to use. I have the 500efi's I was thinking of going with the VR1 20w50
FIVEPTOHH 01-22-2015 09:42 PM
I run Amsoil 10W40 marine oil in my 496 mag HO motors..
http://www.amsoil.com/shop/by-produc...?code=WCFQT-EA
Keith Atlanta 01-22-2015 09:56 PM
Amsoil 20-50 Dominator
Because its red.
realjag 01-22-2015 10:04 PM
Whatever Marine Oil you run with..........you should be using Lucas Oil Stabilizer
harleyrider 01-23-2015 05:54 AM
I run Amsoil in everything I own, my biggest concern is weight. I bought the boat in the fall and the previous owner was running Valvoline racing 50 weight and that's seems to heavy to me.
