Stupid shore power question >
Old 03-03-2015 | 04:24 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
So I guess we are back to basic basics.
Are you turning off the DC breaker when you try the AC breaker? Leave both on. The fridge will default to AC if AC is present. Trying to understand why the fridge is off when you flip the AC breaker on, unless it is a DC only fridge and the DC breaker is off, as long as there are no issues somewhere and it's wired up.
See if there is a power label inside the door.
As for the outlet not working either, is it the GFI by the sink? Reset button in?
US1 Fountain is offline
Old 03-04-2015 | 06:56 AM
I didn't know that it would default to AC, if AC is present. It could be working properly?
When I turn main breaker on, turn fridge AC breaker on, fridge is off.
When I turn main breaker on, turn fridge DC breaker on, fridge is on.
GFI is not tripped. I haven't had a real need for it to work, so I've only checked it a few times. ...and really not looked in to why it is not working. I'll dig in to that one of these days. :-)
ALL_IN! is offline
Old 03-04-2015 | 07:37 AM
You may want to look into the outlet, or leave the breaker off. Wouldn't be good to have a live wire hanging.
Wildman_grafix is offline
Old 04-08-2015 | 09:04 PM
Well just getting to this and have it all taped off and ready to cut. When I drilled a couple of starter holes seems the plastic wants to snap off. Stopped and was wondering what have others used to cut this stuff with?
Old 04-08-2015 | 10:05 PM
Ginger or Mary Ann?
Are you talking about the plexiglass? Take a drill bit and knock the sharp edges off with a grinder, so that the cutting edges are parallel to the drill centerline to where it looks like you will be scraping the plexy off, vs cutting thru it. Kinda like a carbide tipped cement drill. Otherwise with a sharp bit doing it by hand, the drill will want to screw into the plastic and break it out when the tip breaks thru the back side. Unless you can slowly feed the drill in w/o it catching. Drill it to size 1st time, don't step drill.
Old 04-08-2015 | 10:15 PM
Yes the plexi. Can I cut the straight lines with a saber saw?
Old 04-08-2015 | 10:19 PM
Ginger or Mary Ann?
Yes, fine tooth blade and go easy with it
