Low water pressure and running warm
Plugged hose thru transom
With both high temp alarm and low pressure conditions, you have low flow issues
In your pic, did you look at all the vanes and the full length of them to make sure they arent broken off inside the housing, vs just glancing at the end shot?
Yes tool it out and it's all good
Do you have a freshwater flush system?
it would if it was stuck open. and not moving enough water to get it to close .. feel youre exaust if feels hot youre clearly not moving water .or enough water .. easy way to tell ..exaust will feel warm to touch not hot ... if moving adaquate water past the or through the engine ..like for instance running without a t stat it takes large amounts of water to build water pressure as ther is no restriction .. becomes a strait through process .. i had to lower my water intakes half inch below boat to achieve 15 pounds of water pressure without a t stat ... good luck
