Extension Box on a 27 Fever stepped hull >
Old 07-10-2015 | 12:48 PM
I removed the 2 inch drive spacer and gain 11MPH.. Original owner wanted better hole shot. Around 200ish they raised the drive height. They are faster with stock power. Do a seach and you will find what I am talking about..
procharged 454 is offline
Old 07-10-2015 | 01:15 PM
Yea I know they raised the x in that year area. My question was what drive you removed the spacer from. So if I'm understanding you correctly you had stock length drive with a 2" spacer is that correct ?
ealesh33 is offline
Old 10-08-2016 | 04:28 PM
Found this post like to see if there is anymore info on the my drive was 4 1/2 below the bottom put a -2 short things are better but not seeing the speed increase happen 2000 27 fever 600hp 5 blade px5 hydro 70 mph best
dspad is offline
Old 10-10-2016 | 07:20 PM
How many RPMs?
Stock 1.5 XR drive.
I'm right at 600 myself. Same prop. 28 pitch. 74 gps half tank and 4 people last weekend. 79 today by myself and 20 gallons 5100 RPMs.
jtbooten is offline
Old 10-11-2016 | 01:52 PM
5300 rpm
Bravo 1.5
Px5 hydro
70 mph
Slip 13
dspad is offline
Old 10-11-2016 | 01:56 PM
Can't turn a 28 pitch it's nuts
The px5 is 24 pitch
Stock 26 bravo spun up to 5100 69 mph
Boat and motor like the 5 blade
24 bravo 1 5500 73 mph
Have tried a lot of combos i think my X factor I am still wetting the drive to much at 2 3/4 below bottom
dspad is offline
Old 10-11-2016 | 10:44 PM
i have a 93 27 ft fever, getting ready to drop a 540 in. goin to put a imco sc drive on it with a -2 imco lower. 1.5 ratio
what do you guys think would be a good starting point as far as props? and how do know when to put spacers in the drive?
try and bear with me very new to the performance side...
chancer540 is offline
Old 10-12-2016 | 05:44 AM
How much horsepower and how much torque you're max rpm you're looking for also
dspad is offline
Old 10-12-2016 | 12:04 PM
How far below the bottom of the boat is your outdrive
dspad is offline
Old 10-12-2016 | 08:52 PM
Can you send or post a pic I see you have a super charger thinking of a 250 want to see how close it is to the hatch and the front bulk head
Originally Posted by jtbooten
How many RPMs?
Stock 1.5 XR drive.
dspad is offline
