-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Dash warning lights (https://www.offshoreonly.com/forums/fountain/328712-dash-warning-lights.html)
monster693 07-20-2015 05:42 PM
Dash warning lights
Hey guys so I bought a 2004 29 Fever earlier this summer with a 496. Wife and I love the boat but last night we were cruising around and one of the warning lights came on and sounded the buzzer but only for a second then went off. A few minutes later it came on again for a second and went off. Did this about 4-5 times. Water temp was good oil pressure was good drive oil reservoir is full. Ran all the way back to the dock with no other problems. Ran the motor on the hose today and the alarm went off twice before the motor came to temp. I have 2 warning lights but only one was going off. So I climbed under the dash to see how it was wired and the other warning light isn't connected to anything. Any suggestions? Is it normal to have 2 warning lights? Is the one that isn't connected a dummy or should it be connected? Thanks for you help.
monster693 07-20-2015 06:04 PM
Another question is the warning light tied into the smartcraft system?
joew. 07-20-2015 06:20 PM
Typically they both go off when there is a problem. Not sure why you have one not wired. I have twins and they both go off if one motor has an issue which is how it is wired from fountain.
Feverz29 07-20-2015 08:33 PM
I have a dummy on mine as well, but haven't had it go off. I've seen a similar thread in the past on them going off.
Expensive Date 07-20-2015 10:43 PM
Sounds like an IAC valve. Do not continue to run boat, 496's will melt connector..........ask me how I know. Rock auto has them for about $40.00
CanadianFever27 07-21-2015 06:46 AM
My friend had the same problem on one of his 496HO last weekend.. it was the IAC sensor.
monster693 07-21-2015 07:44 AM
Thanks guys, Lots of people have told me the same thing, IAC. I am trying to find a local shop that can scan the codes for me to be sure thats the problem before I go blindly replacing sensors. Expensive Date thansk for the tip on RockAuto.
monster693 07-21-2015 08:42 AM
So checking out RockAuto and it looks like you can get them at Orileys also. http://www.oreillyauto.com/site/c/de...&keyword=ac423
Expensive Date 07-21-2015 10:52 PM
Looks like it, but you have to get the gasket from Mercury the one they come with is different. Also clean your spark arrestor and change the IAC filter, thanks to member " BUP" for the last two tips.
Expensive Date 07-21-2015 10:55 PM
Here is your part #s for IAC filter / muffler and gasket, this is for my ser. # so you should enter your own just to make sure. http://www.mercruiserparts.com/Show_...ottle%2C+Shift
