-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   NON step 35 Top Speeds (https://www.offshoreonly.com/forums/fountain/329694-non-step-35-top-speeds.html)
kreed 03-14-2017 03:40 PM
Originally Posted by 253 (Post 4537337)
approx. 8,000# dry, then add 160 gal. gas, 2 riders, 2 anchors, toolbox, 2 coolers, 50# of misc. stuff you never use and old flat bottom 35's get heavy, but still run very well.
Do you 35 flat bottom guys run Bravo1 props or Hydromotive?
Unlimited jd 03-14-2017 04:31 PM
5.6% slip with 1.36 gears and 6000 rpm.... Good luck
Crude Intentions 03-14-2017 05:09 PM
Originally Posted by Wildman_grafix (Post 4537322)
ICU on here ran his 95 step hull across the scales and I think it came in around 8600-8800. That was with bravos.
Remember these 33-35 fountains are fly weight 30 foot boats.
Phil it was 9500ish for the boat.
tman 03-14-2017 06:38 PM
I have a set of both the hydros are a couple miles per hour faster and are fun to drive use mostly for poker runs and the bravos give me a better cruise speed at a lower rpm mine turn out.
flat rate 03-14-2017 06:56 PM
when we raced the konrad fountain of youth it was 9260 lbs hanging on the crane with nothing in it and 30 gallons of fuel in each tank ready to race. that was a 86 10 meter. that boat and my 92 35 prefer hydromotives.
Brandonb_05 03-14-2017 08:52 PM
Originally Posted by 1428turbo (Post 4441908)
110mph.....35 lightning...blown 540s.....1000hp each.....upriver.....hydromotive 28s.
Must have been on the Pamlico
93fountainsig35 03-14-2017 09:50 PM
i cannot wait to see what mine will run once motors are done....im hoping 80mph :cartman:
kreed 03-15-2017 07:50 AM
What HP are you running and what size Hydros?
kreed 03-15-2017 07:52 AM
What are you putting in for engines?
Unlimited jd 03-15-2017 08:39 AM
509's Canfield heads, crane 168811 cams should be 620 or so
