Anyone know what exact zinc anode goes on the trim tab bracket?
I have a 2000 fountain fever 29 and I'm replacing the zincs on the trim tab bracket. It seems like most boating stores give you a Martyr CMR-1 which looks like it is the right one and seems like a standard on trim tab brackets, but when I go to screw the zinc onto the threaded rod that comes out of the bracket, the thread size on the zinc is too small. I know this is a stupid question but it's annoying. Thanks
Originally Posted by RuninaFever
(Post 4433412)
http://www.boatzincs.com/MER847266.html The zinc does not thread onto the bolt coming out of the bracket; it is held on by a 10-32 nylock nut. |
Originally Posted by HyFive578
(Post 4433424)
This is the anode that goes on K-plane bracket on the transom.
Trying to replace mine also. The old ones are corroded on and I cant get them off.
Originally Posted by monster693
(Post 4433518)
I had one heck of a time getting the cavitation plate anode off (Bravo 3). Our boat is 100% fresh water and it was a lot harder than I would have expected. What I did was just spray some WD-40 on the bolt and let it sit a couple of days - Finally got it off. Replaced all the anodes with Magnesium.
3pointstar |
Just went thru this, a good dose of pb blaster and a day or two of soaking helped a lot. After that some patient prying. I modified the martyr zincs to work , I think the merc replacements are aluminum, no good if you are boating in salt water.
| All times are GMT -5. The time now is 01:09 PM. |
