Bilge pump switch questions... >
Old 06-14-2016 | 08:40 PM
Default Bilge pump switch questions...
On my boat I have 2 bilge pump switches. The switches are labeled port and stbd. Obviously I have 2 bilge pumps. The switches only have 2 positions...either on or off. No way to switch the pumps to auto so that they come on as needed..? seems odd seeing as though the bilge pumps appear to have built in float switches. need some info as to why the pumps are wired with 3 wires but no provisions for a auto feature
FIVEPTOHH is offline
Old 06-14-2016 | 09:15 PM
The auto is hard wired in so you can't shut it off.
joew. is offline
Old 06-14-2016 | 09:17 PM
^^what he said. Hard wired. Out of your control.
Crude Intentions is offline
Old 06-14-2016 | 09:24 PM
ohhh so my floats that are built in the bilge pumps must not be working..?
Old 06-14-2016 | 09:59 PM
Odd for both to go out at once. Check wiring. Bilge pumps usually have 3. Ground. Switch. Float/all time hot. It's possible someone replaced and wired backwards or something. Also the pumps are old. Likely the lovetts. I just yanked those. Not made anymore I'm switching to rule. Motors are out so I'm replacing all the hidden bs. Lol
Old 06-15-2016 | 12:29 AM
yes my pumps appear to be original. and they do have 3 wires going to them. They do not automatically start up if I fill the bilge with water though. If I flip the switch they both work great. just hate having to flip the switch
Old 06-15-2016 | 05:34 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Check your breaker under the seat
US1 Fountain is offline
Old 06-15-2016 | 08:14 AM
Also my old ones the float went bad or stuck. Went with rule for the new ones.
Wildman_grafix is offline
Old 06-15-2016 | 08:23 AM
I'd consider new pumps. 20 years is a good run. Lol. Also what power/speeds?
Old 06-21-2016 | 11:17 AM
Mine are just like this and they automatically come on when needed.
FREAKY FAST is offline
