throttle trim button sticks >
Old 08-07-2016 | 09:22 PM
later's Avatar
Default throttle trim button sticks
Anyone every have their throttle trim button stick, lately my trim button in my throttle sticks in the up position, doesn't do it all the time but often, I have a 98 42 with the white shifters, does the switch come out fairly easy? any surprises.
later
later is offline
Old 08-07-2016 | 09:51 PM
Mine did once, 29 single, sprayed the switch with WD40 in both the up and down position and solved the problem
papps is offline
Old 08-11-2016 | 04:10 PM
Mine stuck down the other day while docking and didn't realize it, burned up the seloineds for the drive trim so be careful if it sticks
T_traylor1 is offline
Old 08-11-2016 | 06:46 PM
later's Avatar
luckily the trim stuck tripped the circuit breaker under the rear seat and didn't fry anything
later is offline
