Port bilge pump install 1990 29 fever >
Old 07-05-2018 | 07:40 PM
Default Port bilge pump install 1990 29 fever
Does the engine have to be pulled out to install a new port bilge pump? Is there communication between starboard & port in the bilge through the main stringer? Can I run the boat with only starboard bilge pump operational?
FTAM is offline
Old 07-05-2018 | 08:08 PM
Yes water can flow between sides. If you run only one I'd keep a spare one with hoses and alligator clips as a backup on the boat.
Crude Intentions is offline
Old 07-05-2018 | 10:09 PM
as cheap as they are id put the second one in
blownzr1 is offline
Old 07-06-2018 | 09:15 AM
If you take the inside headers off you can change them without pulling the motors.
Wildman_grafix is offline
Old 07-13-2018 | 10:14 PM
My port pump was not working (29 Fever w/twin 6.2s) Had to remove both inside exhaust manifolds and the port alternator to replace the pump. It was a bear to replace! JMHO but I would not run with just the one pump. As a side note, had my boat on the buoy during a night of heavy rain. The next day the batteries were flat. Water runs down the sides of the boat and into the air intakes and into the bilge...
Wes Burmark is offline
Old 07-14-2018 | 07:06 AM
in my 32 i did'nt have to remove anything but was rough squatting down and had to fold myself up like a lawn chair it get down to it
blownzr1 is offline
