Latham steering fitting leaking on 08 33 Lightning
I have a loose fitting on one of my latham lines. see the fitting in the pic going into center of blue square whatever it is.If I remove fitting and reseal with loctite 545 will i have to bleed system. Seeing different answers
https://cimg2.ibsrv.net/gimg/www.off...2c07ae6c59.jpg |
Not usually. You shouldn’t lose much fluid and it will bleed itself with a few turns back and forth in most cases.
| All times are GMT -5. The time now is 07:37 PM. |
