-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   38 Express Cruiser Exhaust question (https://www.offshoreonly.com/forums/fountain/375126-38-express-cruiser-exhaust-question.html)
fountain38express 03-19-2022 07:04 PM
Im in the middle of building two 496's, with forged internals from Raylar, 4.5 stroker kits with blower 8.5 pistions. Cam shaft also from Raylar, BP211S, Instake 526 lift/ 231 duration. Exhaust 561 lift/242 duration.
Whipple Superchargers and new exhaust manifolds and risers from seaward.
My question is about the exhaust, I have been told I may have a reversion issue with this cam profile and that I should remove Y down pipe from the exhaust system. Is this true?
Also, if I remove the Y pipe how much louder will the boat be? I dont want a loud cruiser.
Any input or suggestions would be greatly appreciated.
Thank you in advance for any help on this
Dan
flat rate 03-20-2022 11:27 AM
do you have the tailpipes that go under water?
fountain38express 03-20-2022 05:20 PM
Yes the pipe come down at a 45 degree angle, they are in the water until I am on plane
Unlimited jd 03-20-2022 05:49 PM
A picture of your exhaust will help a lot.
flat rate 03-21-2022 07:03 AM
I have the same. I believe the y pipe needs to be there with tailpipes in the water.
fountain38express 03-21-2022 05:09 PM
Do you have any info on that? I would appreciate any info one way or the other. I dont want to get rid of the y pipe, just dont want any issues with reversion.
fountain38express 03-23-2022 07:21 AM
Unfortunately I cant post a picture because I havent made enough posts on this forum. It is stock exhaust setup that all fountain 38 Express cruisers have.
fountain38express 03-23-2022 07:22 AM
Wally 03-23-2022 07:39 AM
you have 3 more posts to go...just do a count down postings... 3....2...1...
fountain38express 03-24-2022 08:23 PM
number 3
number 2
fountain38express 03-24-2022 08:24 PM
number 1
fountain38express 03-24-2022 08:25 PM
Here is a pic of my exhaust
https://cimg3.ibsrv.net/gimg/www.off...4e6fb48fe2.jpg
