how fast?
1 Attachment(s)
I just installed a 2" shorty on my 96 27 Fountain, how fast do you guys think I will run now? My best to date with a labbed 32 rh Bravo is 85.5 on GPS last year and after retuning the prop this summer I got 84.7 last weekend. I also have a stock 30 rh Bravo which will run 83 to 83.5. Anybody tried one of the new five blades on a single yet?
What do you have for power? My 27 has 572 my best was 86 gps w/26 bravo. Just purchased 28 labbed haven't got it from seller yet. Dave
Dave,
I have a 502 EFI with a stage II procharger running 5lbs boost. I was begining to wonder if anyone was interested in my project! Lee |
Indy27
That looks sweet, I will guess you will get 2mph out of it maybe more. My big question is if you will blow out easier in turns or if it will be harder to get on plane?? My boat is set up with a 17.5 X Dim and it is slow to plane off. Will;) |
Keep us posted of your results. Dave
I ran the boat sunday afternoon and got some strange results, after four passes with each prop the 30 was the fastest at 84.2 but the best I got with the 32 was 81! Also lost 8-9 mph at cruise (3000-3500 rpm). I was not able to use as much trim as before and hit the rev limiter (5400) on both props. The boat planed off as good as before if not better and with the 30p the acceleration was much better than before. The boat did handle a little different, it felt more loose in the rough. I plan trying some different props this weekend, hopefully one of the new Hydro five blades will do the trick. Any input would be appreciated!
Lee |
prop
What size you goin to try?
The Hydro 5 blades will help out in the crusing range for sure. I ran a pair on a 35 Fountain. The 5 blades also will give a more secure feeling in rougher water. The top end is where you will have to get Hydromotive to tweek them. They will have to be labbed to get the most out of the top end.
Re: prop
Originally posted by fourplaydave69 What size you goin to try? |
Indy,
I'm interested as well. I'm running a 30" Hydro 4 blade LH lab finished at 5400 for 86mph gps. This is in a Whippled 27'/502 mpi. I'll be interested to know if you see any problems getting on plane with a 2" shorty. Mine blows out (std length Teague XR) if you give it too much throttle getting on plane. I'm thinking about a Hering 5 or even 6 blade but they're big bucks. Thanks, Mark |
Mark,
the boat planes off as good as before if not better, I had the same problem with hydro props. I found a labbed 5 blade Herring 30p rh that I will test this weekend and will let everyone know how it turns out! |
I believe that any of the late model Fountains are not going to gain much if anything by shortening the drive(s). Late model being defined as stepped hulls. I haven't seen one single newer Fountain, of any size, but particularly single engine boats, that doesn't struggle to get on plane. Reggie has milked every possible mph out of the boat hull before you ever buy it. All the tricks have been used to include very high X dimensions. An older non stepped hull might benefit more because the X dimensions seem lower. My boat for example (1991) will jump on plane with no trouble no matter how many are in the boat. I am positive I am giving up a couple of mph on top however. It's a trade off. The problem is it's an expensive gamble to purchase the short drives not knowing for sure what you will receive, if anything, in mph gains. If I could find someone who has tried short drives on a hull like mine and gained something, I might try it out. So far despite repeated posts noone has come forward with experience. You would think that Fountain would have tried everything in testing and could help us all out with some tips. It would sure save us all some time and MONEY! Fountain chick are you tuning in out there? Can you offer guidance?
Curt,
JimV is on the board and has a 92 27' with a 2" shorty and he gained 3-4 mph. |
Originally posted by INDY27 Curt, JimV is on the board and has a 92 27' with a 2" shorty and he gained 3-4 mph. Another problem that the newer stepped hulls could face wth shortys relates to the airating of the water under the hull. If the prop(s) are real close to the surface they may get caught up in the boat wash coming from under the hull, reducing the bite the prop(s) have. I don't know, I am certainly no expert but I have observed a lot from the sidelines. Like I said it would be nice if one of the testers from the Fountain factory would chime in and give us a clue as to what works and doesn't work with these hulls. You know Reggie has tried everything possible to get thse boats up in speed already. |
I ran the Hering this weekend and it handled great but I could only get 83.7 which is not going to do the job!
Originally posted by INDY27 I ran the Hering this weekend and it handled great but I could only get 83.7 which is not going to do the job! |
Oh yeah, I have tried to talk to them but they never return phone calls! No big deal, the people I got the Hering from said to send it back if it did not work for me and a buddy of mine will buy the shorty if I dont want to keep it. You are right though, it is damn frustrating to squeeze that last few mph out, maybe its just not going to run any faster unless I add more power!
Indy,
What rpm do you see 85.5 mph with the 30"? Also, how many #'s of boost is that at? I'm going to go change to the Crane 168741 next season with an ECU change. At 5600 rpm I should get 700+ HP. What do you think your current HP is? Mine's approx. 640 HP at 5400rpm now. |
85.5 with the labbed Bravo 32p rh at 5200 rpm and 5lbs boost.
Indy,
I guess your trials are a testimony to the effective setup from the Fountain factory. I've contemplated the same mods to my drive as well. Your at the point of diminishing marginal returns so any gains will be difficult. One of the things that worked for me was running Mobil 1 synthetic gear oil in the outdrive. It's alot less viscous so the parasitic drag is reduced. Teague recommended running the Mobil 1 (the 75-90 weight gear oil) or Amsoil synthetic. My boat runs 1-3 mph quicker than identically equipped boats running the Merc gear oil. Never any problems with metal on the drain plugs, shifts fine, etc. Also, the XR's have been pushing seals against the yokes due to pressure build up with the Merc lube. The XR, remember, is a "slower" drive, inherently due to larger dia gears. |
Thats exactly what I am thinking, thanks for the tip on the drive oil, I will give that a shot and also may try a labbed 30p hydro. Last year I tested a 29 and a 31 but the 31 was too much prop and the 29 ran the same on top as the stock 30p Bravo but blew out too easily when coming on plane.
Originally posted by INDY27 Oh yeah, I have tried to talk to them but they never return phone calls! No big deal, the people I got the Hering from said to send it back if it did not work for me and a buddy of mine will buy the shorty if I dont want to keep it. You are right though, it is damn frustrating to squeeze that last few mph out, maybe its just not going to run any faster unless I add more power! Dan |
| All times are GMT -5. The time now is 12:39 AM. |
