Fuel capacity increase for 27' Fountain?
Any ideas or recommendations for fitting a supplemental fuel tank for a 2000 27' Fever II? Everyone knows the 27' Fevers have a small 60 gallon gas tank and with a supercharged engine it is easy to run out of gas. Has anyone added reserve tanks to their boat? Something in the 10-15 gallon range would be sufficient. Thanks.
ScottR
ScottR
Just a thought:
My 29 has a 13 gal water tank on port side and nothing is on the starboard side. If the set up on the 27 is similar, you should be able to add a small saddle tank to stafboard area without too much difficulty. Try IMCO and CPPerformance.com for tanks.
F
F
