1996 1 Step Lighting What Speeds >
Old 06-04-2004 | 02:57 PM
TOMMY HIWAVE's Avatar
I HAVE 1996 1 STEP LIGHTING W/ 502'S HYDO'S 27 PITCH 4 BLADES RUNNING 4600 RPMS AND SEEING 63 TO 64 GPS. I TRIM IT UP TO 4 TO 5 ON INDICATORS AND NO TAB.
I HAVE HEARD IN THE 80'S I AM YET TO SEE IT.
A VERY STABLE BOAT HAVE TO USE SOME TAB TO MAKE RUN LEVEL IN THE 3000 TO 4000 RPM RANGE. RUNS RIGHT OVER 3 FOOT WAVE IN THE 4400 TO 4600.
WHAT SPEEDS ARE YOU ALL SEEING AND HOW DID YOU GET THERE. WHERE ARE TABS AND TRIM? WHAT PROP?
TOMMY HIWAVE is offline
Old 06-04-2004 | 03:07 PM
Default Re: 1996 1 Step Lighting What Speeds
What size Lightning? A friend had a '95 35 with 502's and he was seeing mid 70's. You should definately be running faster than 63.
jmeng is offline
Old 06-04-2004 | 03:08 PM
Jonas's Avatar
35 38 42 ? what size?
Jonas is offline
Old 06-04-2004 | 03:51 PM
jryan26's Avatar
Wow thats odd. I have a 32 without a step w/540s and 27 hydros. Im having fuel pressure problems, but @ 4300rpms, Im at 74-76mph
jryan26 is offline
Old 06-05-2004 | 01:41 PM
sorry it a 35 lighting
Old 06-06-2004 | 12:56 PM
22 % Prop Slip To Get This #
Old 06-06-2004 | 01:05 PM
Jonas's Avatar
lab the props get the rpm up.. i ran i think 28 hydros labbed on our non step 35 with 502's prob around 550 hp i had it set up to spin 5150 - 5200 at just over 80.
Jonas is offline
Old 06-06-2004 | 02:24 PM
99 35 lightning single step w/ 502 magnums (efi) spinning 23p Mirage Plus' through 1.36 Bravo 1s. I see 5100 rpm and 78-79. I have twice seen 80.3 with very light fuel and passengers.
4000 RPM equals 60 mph and 30 gph total, almost irrespective of the fuel and passenger load.
Tab and drive settings vary based upon the conditions and "heartiness" of the passengers.
Tom
MegaByte*3 is offline
Old 06-06-2004 | 09:57 PM
Downtown42's Avatar
Fountain will fax you the speed report on your boat. Give them hull ID and you should be upper 70's at minimum. 62-63 something is severely wrong. My 1993 35 non step does 75 502's carb.
Downtown42 is offline
Old 06-07-2004 | 05:34 PM
dykstra's Avatar
1997 29' Fever single 525SC 77mph 5100 rpm
dykstra is offline
