Help needed with Imco shorties >
Old 06-10-2004 | 02:19 PM
Jonas's Avatar
Default Re: Help needed with Imco shorties
they were 502's with merlin heads etc as per teaugue est hp was 550.
Jonas is offline
Old 06-10-2004 | 02:25 PM
toolbox
Jonas,
Thanks for the input.
T.J.
Old 06-10-2004 | 03:46 PM
I would see what happens with some 28" B1's
Back4More is offline
Old 06-11-2004 | 07:08 AM
Zanie's Avatar
What is your prop height with the shorties?
Trim your drives so the prop shaft centerline is parallel with with the bottom of the boat.
Lay a straight edge on the bottom of the boat directly in front of the drive, extending back towards the drives.
Measure the distance from the bottom of the boat(directly in front of the drive) to the centerline of the propshaft.
What is that distance?
DS
Zanie is offline
Old 06-11-2004 | 12:46 PM
Downtown42's Avatar
JONAS, what was your top end on the '92?
Downtown42 is offline
Old 06-11-2004 | 12:47 PM
Jonas's Avatar
low eighteis
Jonas is offline
Old 06-23-2004 | 04:33 PM
Toolbox, any progress with those imco shorties? I was thinking about doing a set myself.
Marginmn is offline
Old 06-28-2004 | 11:19 AM
stevedg's Avatar
One of my boats was a 35 lightning and you will NOT get any speed even with extension boxes. The advatage that the shorties have is when your speed is in excess of 90 MPH. At this speed or higher you could expect to see 3-5 MPH over stock length drives. Also keep in mind that fountains have a very high x-demension already, the hulls are pretty much tweeked as much as possible at the factory.
stevedg is offline
hangem out 2dry
Cigarette
4
09-26-2008 02:25 PM
cstobe
03-26-2006 06:11 PM
SCRAPMAN1
02-23-2006 10:12 PM
SCRAPMAN1
General Racing Discussion
3
02-23-2006 10:09 PM
toolbox
11
06-13-2004 02:07 AM
