Oil
Old 02-03-2005 | 11:22 AM
Default Oil
What oil do you'll recomend running in stock 1992, 502 carb. motors.
alpine99 is offline
Old 02-03-2005 | 01:24 PM
pachangalpina's Avatar
Default Re: Oil
I have always run RedLine 40wt race with just enough of their 10-40 to get some additives per their suggestion.
pachangalpina is offline
Old 02-03-2005 | 02:19 PM
Default Re: Oil
Pachangia thanks for the info.
alpine99 is offline
Old 02-03-2005 | 04:20 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: Oil
I prefer the Merc oil myself. Been told it has additives to fight condensation more than regular oils. Don't know fact or fiction thou
US1 Fountain is offline
Old 02-04-2005 | 08:18 AM
DragonFire's Avatar
Re: Oil
Mobil One....
Change the oil + filter every 10 hours...
It's the Life's blood of your motor.......
DragonFire is offline
Old 02-08-2005 | 09:03 PM
Registered User
Default Re: Oil
If your motor has Roller Cam setup use Merc 25W-40 oil. If it has flat tappet cam setup use Amsoil 20w-50. Synthetics in a stock roller setup will allow the rollers to slide on the cam instead of roll and wears flat spots in the rollers. This applies only to stock motors using stock valve springs. Raise the spring pressure and synthetic is the way to go. BTW ... Merc oil has produced the highest oil pressure numbers in any motor that I have ever seen. Think it holds its consistency well under extreme use.
- Vinnie
HPFountain is offline
Old 02-11-2005 | 11:23 AM
Default Re: Oil
I saw some roller rockers get flat spots on the roller tips...the guy was using syn. Mobil 1. in his 525SC's
Back4More is offline
Old 02-11-2005 | 04:55 PM
Registered User
Default Re: Oil
The synthetic oil is way to slippery to use with stock components. The rollers in the rocker tips were not rolling ... instead they were sliding on the valve stem.
- Vinnie
Old 02-13-2005 | 09:35 AM
DiamondPerformance's Avatar
Offshoreonly Advertiser
Default Re: Oil
Stock motor, use Merc.
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 02-14-2005 | 07:45 AM
dykstra's Avatar
Default Re: Oil
Look up some past threads with "Hydrocruiser" he is da man with oil knowledge. Very informative.
dykstra is offline
