Trim Rams On Fountain 35
Does Fountain Put A Shorter Trim Ram On On Twin Setups To Avoid Hitting The Swim Platform And Having External Steering?
The Reason I Ask Is That When The Drives Are Tilted All The Way Up To Where The Pump Bottoms Out The Drives Still Look Somewhat Down. It Does Not Stop Due To A Limit Switch, It Just Runs Out Of Ram! I Think I Have Seen 2 Different Size Rams In The Past. Anyone Elce Seen This? |
Re: Trim Rams On Fountain 35
No different lenghts, Still gotta go from gimble to the drive. That is a set measurement. But possibly you have spacers installed inside the rams to limit the extended length. Heard of that being done before, just not familiar if done on Fountains. My 32 'appears' to have the full travel
My 2003 35' Fountain Drives Don't Go All The Way Up Either.
I Found A Part # 15768a3 On The Mercury Parts Look-up Called A Tilt Limit Kit But It Does Not Have A Picture Or Any Other Information. I Will Look In The Service Manual Tonight And Post What I Find. If I Don't Find Anything I'm Going To Take One Apart And Look Inside. I'm Afraid That It Is Going To Drag While Trailering.
Lesroll,
Are You Gill Fron Louisiana? |
2 Attachment(s)
Also Found This?
Sorry Item 27
I seem to remember an offset bushing or elongated hole that the rear attachment of the ram mounted through. Maybe somebody else here will know more about that.
When a bravo 1 is converted to an xr setup I was told to install these limit spacers by Max Machine. Because of the larger universals if no spacers ,the u-joint will bind if raised to far. David
| All times are GMT -5. The time now is 03:55 AM. |
