Which octane fuel do you use? >
View Poll Results: Which octane fuel do you use?
87 octane (regular)
44
23.78%
89/90 octane (plus)
27
14.59%
92/93 octane (super)
97
52.43%
AV/ other or Allan 4 is a putz
17
9.19%
Voters: 185. You may not vote on this poll
Old 04-11-2005 | 06:38 PM
Sean H's Avatar
A to Z
Default Re: Which octane fuel do you use?
Originally Posted by Bigyellowcat
called my motor guy and he said it would not drop to that low of hp to set it up to run on 87
1400 on 87? now that would be a sweet deal....
Sean H is offline
Old 04-11-2005 | 06:39 PM
Sean H's Avatar
A to Z
Originally Posted by CMG
87, the only time I don't mind having black motors is at the pump.
blue motors w/o blowers run 87 too....
Sean H is offline
Old 04-11-2005 | 07:28 PM
traviss's Avatar
good ole 110 octane...
traviss is offline
Old 04-11-2005 | 07:38 PM
mikes280's Avatar
93 for me and i know all of you are getting ready to drag the boats out just remember the old gas in the tank will not be as high octain as it was in the fall might wont to put some additive in and run it easy to you can get some of the old fuel out and some good in
mikes280 is offline
Old 04-11-2005 | 07:50 PM
Cmoney's Avatar
Originally Posted by C_Spray
600hp/540 ci Innovations - 89 octane, but knock sensors will allow me to use 87 in a pinch.
Same Here.
Cmoney is offline
Old 04-11-2005 | 08:08 PM
you guys running 87-89 in 500's...what temp are you running in and how hard?
This will be the first season for me with 572ci 650's, I plan to run 93. I always ran 93 with 425's too.
TxHawk is offline
Old 04-11-2005 | 08:22 PM
JCPERF's Avatar
114 octane when my wallet can afford
JCPERF is offline
Old 04-11-2005 | 08:25 PM
Outdrive1's Avatar
Masher touches my
I always ran 87 in my 502 mag mpi with no problem or excess soot on the transom. When I put the Vortech Supercharger on the knock sensor kicks in around 5100 rpm even with premuim gas, so I run A/V gas now with no problems. All Merc motors are designed to run off 87 octane just like every one is saying in the thread. Dont waste your money on anything else, it won't make a diferrence. I do believe that Chevron with Techroline is good on your injectors though. Its supposed to help especially with Gm injectors wich are known for clogging and failing.
Outdrive1 is offline
Old 04-11-2005 | 08:26 PM
It's just amazing how many people, even supposed motor-heads, have no clue what the real function of octane is. All you need to do is read a little and get the real scoop.
Compression, compression, compression. If you don't run a high compression engine, you don't need high octane. Octane prevents pre-ignition caused by compression. In a higher compression engine, the fuel/air may (will) explode under compression before the piston reaches the top of it's stroke. Imagine the stresses when that happens. That little "knock" you here is your piston being jammed back down on it's up-stroke. Not good! However, as many have stated above, if you don't need it, don't spend the money on it.
ThirdBird is offline
Old 04-11-2005 | 08:34 PM
Do tell...what kind of motors are you running?
Byrdman is offline
