Impellers that dont burn out
Found a company at Zuls today that makes sea pump impellers that can run dry and not burn the blades off the impeller.Its a company called Globe Marine.The impeller looks like a Mercury impeller but is blue.It has a special coating on it.Not that expensive either.
Re: Impellers that dont burn out
sold!!!!!!
Originally Posted by dreamer
sold!!!!!!
I'm in...........
Will have a pic of it and the box it comes in tommorow
In! Twice.
They have been around for a while. Your engine will run 8-15* warmer with a Blue Globe over standard Merc impellor. I am pretty sure they have some type of teflon/silicon to their construction. Do a search; has been info on them in the past here on OSO.
Bevery careful with the Globes. They are softer and more flexible that stock impellers. They will run hotter due to lower flow and they have been found to have problems in engines that see extended high RPM usage. I just had one fail on me and it looked perfectly fine, just wouldn't move water. If your engine is basically stock it should work fine, and they wil run dry with no burn out.
I'm in! Post a website or number if anyone finds one?
| All times are GMT -5. The time now is 12:38 AM. |
